I got a set of 17" wheels with New Falken Semi on it..
I think it is 255/45/R17 all round
I am in Brisbane
Prefered Pick up
Asking $1300
Dun ask about will I just sell the tyres.
if any question, ask here or [email protected]
Edited by Stephen22
I'll tell a mate about these tomorrow, he's after some wheels like that.
By the way, They aren't a true 'semi slick', as they have a treadware rating of 200 and are just a good road tyre which has a stiff sidewall suited for track use.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
