hey aidan, just to let you know, i just got one about a week ago and paid $25 inc ex post! (i think i was lucky)
try posting in the wanted section if you have not already
yeh posted in every state section and in the wtb
maybe i could borrow yours for the drift day then give it back if i dont get one haha!
that would be tip top! found one on ebay but doesnt end for 2 more days, will wait and see... I might need to get someone who is pretty clued up on turbos to have a quick look at it first cause when spinning it by the exhaust wheel it makes a clipping noise, not when spun by intake... and no noise if you push the exhaust inwards as you spin it, was told it was working fine on car not missing a beat just when removed they discovered this noise.... so hopefully should work fine as is.... or just rip the ex wheel to bits lol
Edited by da_snuff
Hey ppl.
soz dont have a r33 elbow would also love one myself though. I have 2 bloody r32 elbows and need a r33 one
so if there is a 2nd one out there then yeh would b apreciated aswell..
cheers nick
hey nick, think i might have found one for ya! and one for myself ;)
will pm you where to find it :P
oh yeh and i always see ure car outside my dads place, near woolworths, and its lookin good these days :)
Edited by da_snuff
i think thats the one we need by the sounds of it. its the one that goes from the turbo to the intercooler and i better let da_snuff have that one as i asked 2nd
cheers arsnik
the one i have is the standard cast elbow thats bolts to the back of the turbo (exhaust side) is this what he needs?
cheers toff, was at josh's just before and the car is gettin there, will be tuffffffffff :P
we're gonna hav to put ure name down the side of the car for all the parts uve donated :)
cheers mate
arsnik, if you have any trouble getting one now, ive got heaps of names of people willing to get rid of em haha
aidan
ive definately got one and im giving it to jp if you still need it :)
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
