A couple things i have in my room must go due to the fact i am moving house and just don't have the space.
All parts are off a 97 S11 skyline.
1x pair of standard r33 castor rods. $50
1x Standard R33 suspension $230
1x standard air box plus flute $75
1x r33 standard intercooler (with some piping) $50
1x HKS copy pod filter near new condition $20
1x Autometer cobalt gauge (water temp) $120
1x Fusion dual 15in sub box ( black carpet, unused) $120
1x Pair of focal polyglass 6.5in speakers (3 months old) $160
1x JVC head unit (pre outs, non MP3) $50
If any one is interested pleae PM me.
I am located in SE suburbs of melb
EVERTHING MUST GO
prices are all neg.
Thanks DAN
Edited by DNR33
https://www.sau.com.au/forums/topic/120571-random-parts-r33-all-must-go/
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
