who is going to gepps cross drive in, and who would like to meet up @ respective sides of town and meet there on the night or @ harvey norman car park up the road from mainline
im leaning towards seeing it might be better than last 1 which i didnt see :D
https://www.sau.com.au/forums/topic/120630-tokyo-drift/
  • Replies 64
Posted Images
id rather see it at the movies, the drive in isnt the best qualityyyy
but im up 4 it if we have a little group, make all the other ppl jealous that we got our own fast n the furious club lol.
That's OK because the movie wont be "the best qualityyyy" either. :dry:
https://www.sau.com.au/forums/topic/120630-tokyo-drift/#findComment-2223761
how about we just make a time, and whoever can make it..just turn up? do u think the late night session on tursday 15th will b packed at marion? or would it b worth waiting for the fri nite 2 see it?
I'd come but wouldn't leave my car parked in marion that's for sure..
imagine all the mofo's coming out of earlier sessions all hyped up after seeing the movie..then see a whole heap of skylines, guess what they'd do.. Jealousy can be pretty nasty at times..
https://www.sau.com.au/forums/topic/120630-tokyo-drift/#findComment-2228381
if we park right at the front where new york bar n grill is, slip the bouncers a $50 and im sure they will look after them 4 us haha
we could park underground right at the bk when no1 goes...that should b ok...i feel invincible now with my new alarm.lol
https://www.sau.com.au/forums/topic/120630-tokyo-drift/#findComment-2228435
Personally i will pass on either..... don't really feel the need to see it until it comes out on DVD!!!
Nor do i really. But I'll go as an excuse to socialise with the crew. However, I wont be Gold Classing it.
i agree not fased on if i see it but would be good for SAU to meet sumwhere and have as many of us drive into the drivein would be good :D:ermm::D
https://www.sau.com.au/forums/topic/120630-tokyo-drift/#findComment-2229359
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
