Not sure if this is the right section and not sure if been covered as i searched though couldnt find it! I have a stock 32 gtst with just an apexi pod, im gettin a new exhaust fitted this week, 3" turbo back, hi flow cat, was just wondering if this will increase my boost? My car is just running stock boost - 7PSI. Any information would be great.
Cheers
https://www.sau.com.au/forums/topic/121224-32-exhaust/
with the exhaust you will notice better spool time, and more power.
I did with my crappy old red-top, so the silver has gotta be better again.
stock I/C is definately on the limit, no need for a boost controller till you've change the I/C to a R34 side mount, or bigger
https://www.sau.com.au/forums/topic/121224-32-exhaust/#findComment-2233815
it'll be around 10psi if i recall, each car seems to be different of course.
Get a boost gauge and see :)
I believe the R34 is a drop in.
Check the sticky thread, and this link. Its probably got the infor your after, i just dont have time to go through it for ya
http://www.skylinesaustralia.com/forums/in...showtopic=54854
https://www.sau.com.au/forums/topic/121224-32-exhaust/#findComment-2233866
R34 sidemount is "NOT" a direct replacement for an R32..
it "IS" a direct replacement to an R33 or a stagea.
to fit an R32, you need to do one of 2 things to fit it.
1.) make changes to the piping down near the cooler to fit the new inlet angle.
or
2.) take your R32 stock intercooler and your newly purchased R34 side mount intercooler to a local aluminium welder (just find one in the yellow pages) and tell them to weld the end tank on the r34 cooler so that the pipes face the exact same direction as teh r32 cooler.
now it will bolt straight on.
note.. this above information is pretty much what Sydneykid wrote in another thread of what he did to mount an R34 intercooler to an R32.
the welding job cost him about $50 if I recal.
https://www.sau.com.au/forums/topic/121224-32-exhaust/#findComment-2236715
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
