man where where would you go to get a 4inch exhaust made up, i think the extreme bit would be that fat pipe hanging 4 inchs lower than the rest of your car
True it would hang down a bit...
I was offered this exhaust from someone for $1000.00 it’s from the cat back and it's made of titanium.
That’s why I was asking about the size...
It's in a shop in box hill down Station Street. It’s on display but the guy who owns it was asking me if I was after it. He said it’s a copy of the veilside r32 gtr drag car exhaust and a customer had ordered it but it was taking too long to arrive from Japan so instead the customer had decided to just get something else.
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2239350
$1k for a cat-back titanium exhaust IS cheap.
Also, it wouldn't hang 4 inches lower underneath it would hang about an inch lower than a 3 inch exhaust which if fitted/made correctly doesnt hang that low at all (providing standard ride height is kept).
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2244320
this may be slightly off topic but why do soo many ppl only have cat backs ? wouldnt any turbo car have a better gain from a turbo back ? and for the small amount of extra money its not liek ppl cant afford it ?
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2247004
It was only 12 months ago that I got a full 3 inch from turbos back fitted, I’m running a pair of garret GT25 60R 14psi atmo.
Will there be much difference if I was to fit a full 4 inch from turbos back.
I would like to hear some feed back if anyone else is running a 4 inch and see the differences to 3 inch system.
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2247573
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
