My problem is this,
The heater in my cefiro wont blow any warmer than not quite lukewarm. When you slide to temp control down to cold, it blows cold just fine. I pulled the heater control out of my a31 parts car, and I see that the control is all electrical. Does it control the temp by means of a water valve, or by means of a door which governs the amount of air which is allowed to pass through the heater core? Where is this mechanism located? I'm in NZ, and it's bloody cold here this time of year. The heater in my parts car works a treat, but it's much too much work to change the whole heater over. I see there is a wee vent thingee in the heater control panel itself, which apears to have some kind of diode or something in it. Mine could be damaged. Does this have some bearing on tempature control? I can swap the whole control panel over no worries. But Like I said, it's really cold here, and I'm getting too old to drive to work in the morning having to wear gloves.
Any advise apreciated.
Bart.
https://www.sau.com.au/forums/topic/121363-a31-heater-wont-blow-hot/
dunno exactly what to check in ur case. though i do remember in my previous r32, it had a air temp sensor in the centre console, after doing a stereo instal i must of knocked it and it had fallen off its mount and was gathering the temp coming of the gearbox boot cover which confused its main unit and in the end wouldn't let me use the heater either....after putting it back up in its spot gave me hot air again. :laugh:
from memory heater core is run via water valve that circulates ur coolant fluid to the core.
kinda a pain that the A31 doesn't have the electronic face with digital display that the r32 uses as i believe it has a diagnostic mode that can show where problems are coming from.
Edited by skypy12
Can anyone tell me where exactly the heater valve is located? I REALLY don't want to have to dismantle the whole dashboard just to find the valve.
I guess thats the drawback with modern cars, Too many parts.
Your probably best calling or going into a aircon-heater-auto elec place and seeing where they recommend looking. I'm sure the australian delivered maxima or some other nissan of the same era would have a similar setup. I tried looking on the FAST software to no avail...
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
