Hi everyone I need some help, :
I have an r33 94 s1. Now the problem is when I start the car when its cold it will start to misfire and lose cylinders for about 5 seconds and sometimes won’t even start 1st go. You need to push the accelerator to get it going but after that it runs ok.
I’ve changed the plugs, fuel filter cleaned AFM with carby cleaner and still doing it but only when it’s cold. It’s running splitfire aftermarket coil packs and iridium plugs
Mods:
FMIC
Exhaust (turbo back)
Turbo smart plump back BOV
K&N POD filter (cleaned)
ECT…
I was thinking it could be a faulty AFM ? Going to do a ECU diagnostic to see what that tells me.
Any suggestions will be great guys. It’s really annoying having to struggle with it in the morning… :dry:
Thanks,
Alex.
https://www.sau.com.au/forums/topic/121515-cold-start-problem/
do you regularly run your car low on fuel?
has the same fuel filter been in there a while?
if YES, then theres a good chance the injectors are slightly clogged with sediment from the tank and open again when enough fuel pressure backs up and forces them to squirt open.
try taking them out and getting them cleaned, or try a mates' injectors in there.
Thanks for that will look into it tommorrow arvo, will also be trying my mates AFM see if that helps.
Also will be changing fuel pump at some stage.
Any other suggestions will be great.
Thanks,
Alex.
let us know how it goes for everyone else on here with the same probems!
Ok 1st attempt was this arvo. I tried my friends AFM to see if it was a possible problem. Nope still struggled to start, also checked the wires on the ECU and around the engine.
Still need to do a ECU diagnostic test to see if all sensors are working.
Any other suggestions :?
I got the same problem.
There was another similar topic and the guy used a bigger battery and said it fixed the problem.
My dad reckon its because I always run the car until i literally almost run out of fuel so dirts getting sucked in as SLIPPERY mentioned
is your car auto?
is your car auto?
Nah manual, yes fuel system is my main concern now. I think the injectors are blocked and need to be cleaned.
I will be running a good injector cleaner thru it see how that goes. I used one on my old R33 and it helped alot.
Cheers,
Alex.
If the fuel system comes up ok, check your plugs for any rustyness and also try to swap AFM's with someone as they can cause hard starting when faulty.
Have been done if you seen the above posts.
Cheers,
Alex.
Sorry, I did read that the day you posted but forgot when I posted today.
Did you reset the ECU after the install of the other AFM?
Sometimes a leaking injector can cause starting issues as they leak before the initial start and 'flood' the bore which can make it difficult to start.
Also does it make any difference if you wait for the pump to prime, then start?
Very dirty air filter can cause hard start.
Dirty throttle body....unlikely but possible
I am another who has this same problem. I found this searching the net. I dont know how relevant it is but I will try anything to make my car easier to start when its cold. "Now, from what you describe you should check the plugs first to see if you have a leaky injector and that could be the cause of the no start condition when cold. Pull the plugs and if you find one or more that are especially black you have found plugs that are running rich. What is probably happening is that the injectors leak down on those cylinders when the engine gets cold and then it makes them hard to start. " What do you think ppl?
No didn't touch the ECU
Tried waiting for the pump, nope still the same
Cleaned my K&N spotless
Will clean the throttle body and idle controller.
OK.. Ran the ECU diagnostic just then and I got an error. 2 long flashes and one short.
Was trying to figure out the codes on the manual and I came up with "IGNITION SIGNAL SYSTEM" OR "AIR FLOW METER" Because its ether CODE #12 OR #21.
I don’t know whether the code is read from left to right or the opposite. I have attached the codes anyway.
If anyone can help on the code that will be great.
Cheers,
Alex.
maybe coil packs or ignitor module
Is it that little black slim black controller at the back of the coils/plugs cover?
How ever ill test my mates coils and ignitor module...
After this saga is solved ill do a "Step By Step" on what i done to solve the problem.
Cheers,
Alex.
Cheers,
Alex.
Can anyone confirm that ignitor module location? Just to make sure im on the right track.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
