PHATR32 Posted June 12, 2006 Share Posted June 12, 2006 hey guys, my stupid master cliner is leaking fluid from between it self and the booster. (the paint on the booster is now f**ked) anyways, are there rebuild kits available? got any prices? prices for labour in perth t rebuild it? thanks guys steve Link to comment https://www.sau.com.au/forums/topic/121980-master-cylinder-leaking/ Share on other sites More sharing options...
djr81 Posted June 13, 2006 Share Posted June 13, 2006 You will most probably find you have to leave it with someone as when I needed mine done exchange master cylinders couldn't be found (last year sometime). Perth Brake Parts may be a good start. Link to comment https://www.sau.com.au/forums/topic/121980-master-cylinder-leaking/#findComment-2250587 Share on other sites More sharing options...
PHATR32 Posted June 13, 2006 Author Share Posted June 13, 2006 well i called nissan, and asked for a whole rebuild kit, they quoted me $200. so then i called perth brake parts, and they want $230, to use their own seals etc. it would be cheap to get the oem parts i need! accord to FAST the r33 gts/gtst and the r34 gt/gtt boosters all have the same internals. (same part number) i wonder if itll make a differaqnce in the price/availability. steve Link to comment https://www.sau.com.au/forums/topic/121980-master-cylinder-leaking/#findComment-2250825 Share on other sites More sharing options...
PHATR32 Posted June 13, 2006 Author Share Posted June 13, 2006 anyone know if the internals off a r33 cyl will fit a r32 gtr cyl? Link to comment https://www.sau.com.au/forums/topic/121980-master-cylinder-leaking/#findComment-2253328 Share on other sites More sharing options...
Birth Posted May 3, 2007 Share Posted May 3, 2007 PHAT r32 - I have the same problem - did you end up sorting this out? Link to comment https://www.sau.com.au/forums/topic/121980-master-cylinder-leaking/#findComment-3095331 Share on other sites More sharing options...
