  • Replies 291
Posted Images
hey guys, anyone going to watch the victory this year, they have some guns recruits and i am thinking of getting a membership. they have 3 new brazilians and a new scottish guy in, seems like the strikers are going to be fighting for a spot :P
cyas
well said biasa! the fact that its zidane, and his last game means SFA. the rules dont change when its your last game, or a world cup final.
materazzi got him to snap, and zidane got sent off. as a result he wasnt on the pitch to cry when his team was defeated
i love how people try to overshadow the win with this shit.
Your comparing Roy Keane to one of the greatest players of all time, playing in his final game which happens to be a World Cup final. So i think your example is a bit far fetched dude >_<
that 'greatest player' is not the greatest afterall..
french lawyer sueing and trying to get the final to be replayed...
LOL!
get over it already. any other player and we wouldnt be hearing/reading/having to put up with any of this BS.
zidane headbutted someone, and got sent off. if materazzi provoked him and wasn't caught, then he gets to play out the match...
Italy - World Champions 2006.
thats all anyone needs to worry about
seeing as how people insist on pasting articles...here's a bit of an evening read you may enjoy
FIFA prez says Zidane could be stripped of award
"The winner of the award is not decided by FIFA, but by an international commission of journalists," Blatter said in Wednesday's La Repubblica. "That said, FIFA's executive committee has the right, and the duty, to intervene when faced with behavior contrary to the ethic of the sport."
"I was told that at the end of the game the French federation executives asked Zidane to go and receive his medal, and he replied that he didn't deserve any medal," Blatter added.
Zidane knows he doesn't deserve it...:yes:
"I held his shirt for a few seconds only, then he turned round and spoke to me, sneering," the Italy defender said. "He looked me up and down, arrogantly and said: 'If you really want my shirt, I'll give it to you afterwards."'
"It was one of those insults you're told tens of times and that always fly around the pitch," he said.
and possibly the best bit of it all...
Media reports, based on interpretations by lip-readers, have suggested that Materazzi called Zidane a terrorist or insulted his mother or sister. Materazzi denies these claims, too.
So basically the "experts" have determined that he either said:
you're a terrorist....
or
you're mother/sister is a whore...
Good old "experts"
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
