Tip for the day...don't buy at BP Toowong (cnr Jephson & Sherwood Rds)...their fuel is the dearest around. Regular unleaded hovers between 133.9 and 135.9 and with Ultimate roughly 10c per litre more expensive, I may as well live in Rocky with Cy :thumbsup:
I can drive to Graceville (5 mins away) and pay the above prices for Ultimate and the other good thing about the BP at Graceville is that its a 7/11 and therefore WILL accept the BP fuel voucher from Action supermarket.
The only other BP I have found that will accept the BP fuel vouchers is the BP on Fairfield Rd at Yerongpilly (sp?) or Yeronga (not quite sure of where the suburb changes).
  • Replies 45
I got the whole docket thing worked out too, and we dont have to spend anymore than we should on groceries:
1. Shop at Action and buy normal stuff, no meat or fresh produce, get 4c/ltr off.
2. Use 4c/ltr docket at BP, there is only 1 BP in rocky that has ultamite, and get tax invoice.
3. Shop at local foodworks and buy meat and fresh produce only, which is usually the cheapest anyway, and get another 10c/ltr to 15c/ltr off the fuel receipt.
Lucky everything is very close here in rocky, so instead of paying the usual ~150c/ltr for ultamite, I end up paying ~135c/ltr, which aint bad, too bad the Stagea is a tank and drinks faster than a russian on death row! Meh the price I pay for driving a slow volvo.............. :thumbsup:
for those skyline owners in caboolture/morayfield... the best prices are usually at the Shell servo along morayfield road... yesterday they had fuel (normal 92octane) for $1.21 where as the caltex up the road had it for $1.36... i lined up for fuel at the shell yesterday, paid $1.31 for optimax...
damn fuel prices... althought i get a pay increase in september just to accomodate for those prices :thumbsup: and there aint no way i am going to be selling my gt-r... when i get it that is
Tuesday is the best days in cab/morayfield for fuel... usually pretty cheap...
Edited by gtr_r32_reddy
That is my local!!! woot..It is just barely in Yeronga It usually has pretty decet prices too
Tip for the day...don't buy at BP Toowong (cnr Jephson & Sherwood Rds)...their fuel is the dearest around. Regular unleaded hovers between 133.9 and 135.9 and with Ultimate roughly 10c per litre more expensive, I may as well live in Rocky with Cy ;)
BP Cannon Hill cnr Creek & Wynnum Rds accepts them too.
Paid 138.9 for Ultimate at Toowong on Monday arvo - must've got lucky with end of long weekend
Only the ones with two heads :domokun: I tie a balloon with a smiley face on it to my shoulder to fit in :(
139.1c/ltr this morning
Weird thing:
136.9c/ltr in rocky last night, and it was 130c/ltr in Yeppoon last night as well....
After 9pm every day seems to be the right time to shop.
Im sure i could arrange express post for you Cy It could be there by next day arvo ? :whistling:
Edit: I just remembered where you lived
It will be there the next day the following week :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
