As my brake pads have worn out, it's now time to get a new set. I've done a search on the forum and could not exactly find what I am looking for. I don't need those that will stick your nose to the windscreen once you slam the brake as I am quite happy with the stock Nissan ones. However, if I can get a better ones would be great, as long as the price is OK... prefer not to spend over $130 a pair.
I heard that Bendix Ultimate are pretty decent and would probably meet my criteria, but I heard that they are very dusty. How much better is the Ultimate compared to the Advance (basic ones)? I also heard Hawk and RB (Racing Brake) are pretty decent brands, but don't know where I can get them from.
Your recommendations are much appreciated! Would be good if you could include the price and place where I can get them from in Sydney
Cheers,
DD
https://www.sau.com.au/forums/topic/122287-brake-pads-for-r33gtst/
Bendix Ultimates are ok for street but I'd go with Ferodo DS2500's
You can get the Ferodo's from V Sport.
The Bendix Part numbers (which most other companies can cross reference with) for the pads are: DB1170 for the front and DB1220 for the rear.
Cheers,
DD
Race Brakes Sydney at Wetherill Park can supply all the brands you mentioned 02 9609 1101.
What's the deal with Ferodo brake pads? Heard a good wrap about the DS2500 series, but went to the website (http://www.ferodomotorsports.com/main.htm) and they only have the excel, formula, premier, GP2 and 4WD series.... Does this DS2500 series actually exist?
Also, is it OK to run different set of brake pads / rotors on front and rear? Thinking of getting slotted rotors with decent brake pads for the front, but leave the rear as is (stock)... is this a reasonable approach or just plain dangerous?
Thanks
DD
Thanks
DD
I've done that mate, have Slotted rotors on the front and stockies on the rear as fronts needed replacing anyway. Works a treat, i asked the same question before i did it and everyone said it was fine to do.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
