hey guys,
I'm buying an R32 GT-R off my friend, it's had $15,000 spent on the engine alone, body works is in fairly good nick, and do you guys think that $25000 is a fair price for it, i think it is, cause of the work that has been done, and it's been professionally tuned at Mercury Motorsports, and has just had the gearbox replaced. I'm replacing a 97 TF Magna, with this, and hope that I will be happy (at the moment i can see that i will be). Just wondering what everyones thoughts would be, i know insurance is hexy, and parts (if it breaks) are a bit pricey as well, but i just wonder wat everyone thinks.. and no, there are only 3 people in the world that will be allowed to drive it, Terry (mate of mine, Myself, and My GF (when i get another one)...
https://www.sau.com.au/forums/topic/122292-buying-r32-gt-r/
yeah there is recepits for the work,
the entire engine was rebuilt, new forged pistons, new gearbox, tuned to 22psi boost if i remember correctly, it had ecu modified, suspension was replaced, some new electronics, heavy-duty clutch, and fly wheel, clutch plates, all up was around $15,000 if i remember correctly...
this car will basically become my pride and joy, and no one can touch it, not even to move it out of the garage, its getting a final tune before i recieve it, around 330kw at the wheels when it's finished, and four brand new tyres so it can pass roadworthy
https://www.sau.com.au/forums/topic/122292-buying-r32-gt-r/#findComment-2258111
It is only worth as much as you are willing to pay. $25k is not bad for the work that has been done (especially the gearbox)
As people have said there are a lot around at the moment for less but these are not worth anywhere near what yours sounds like. If you can afford the insurance, then go for it. If you cannot afford comprehensive insurance then don't even think about it as these cars are targets!!
https://www.sau.com.au/forums/topic/122292-buying-r32-gt-r/#findComment-2258360
my only doubt about getting the car
what is the most likely thing to go wrong in a car like that, and how much do they normally cost to get fixed?
This information would come in handy for me aswell. I'm selling my 31 coupe and was going to buy either a R33 S2 GTS-T or a R34 GT-T, but have seen a few R32 GTR's for sale and I'm being tempted into having a look at a few this weekend.
So if anyone can give me any ideas on what to look out for on a GTR, please let me know :rofl:
https://www.sau.com.au/forums/topic/122292-buying-r32-gt-r/#findComment-2262505
hey guys,
do not let your future gf drive your car she will break something bahahahaha
https://www.sau.com.au/forums/topic/122292-buying-r32-gt-r/#findComment-2262608
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
