Hey guys my GTR came from japan with a blitz ID Power Meter.This is all good so far but the way it was wired into the car was not to my taste (at least they didnt drill any holes).ok now while i had an alarm fitted i told them to disconnect the ID meter so i can later wire it the way i wanted to, that time has come :D
ok now it has a red wire and an extra red wire spliced into it, one black wire and a white wire which must of been short so it was extended with an orange wire (must of ran out of white)
now im guessing the:
RED- power (but why is it spliced and now there are 2 red wires)???
BLACK- Earth ???
WHITE/ORANGE- I have no idea ???
Does anyone know what/where the WHITE/ORANGE wire goes.
Where should i get power from?
Anyone have a diagram for this that they can post.
I have attached a pic i took of the whole thing (sorry about quality of pic its from a camera phone.post-7189-1150683639.jpg
Thankyou
Thraso
https://www.sau.com.au/forums/topic/122818-blitz-id-power-meter-installation/
Thanks heaps michael :P
i guess that pic is the back of the standard GTR comp and shows where to connect the white wire ?
I have one red wire but its spliced to make 2? should i get rid of one? (i have attached another pic highlighted)
Where should i get power from ?
Thanks
Thraso :D
Thanks
Thraso :D
- yeah that correct, thats the stock gtr ecu pin layout.. basicly fine the wirer in the loom which goes to that pinout and connect it to that
-hmm not sure why the red wire is spliced into 2 maybe chop that off. i jsut connected mine to the power wired that goes to my deck
Yeah thats what i was thinking about the red wire just had to be sure.:)Is there a wire there already in that slot for the ecu?
If so do i connect them together into the ecu?
once again thanks alot Michael.
Thraso >_<
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
