Hi
After much debate on boost control, I've finally purchased a SAFCII and Blitz DualSBC Spec S boost controller for my car. I was wondering what is the best way to tune the two available files on the SAFC in as i'll be installing both at the same time (no doubt with a little help)? By fuel type (ie 1 map for 98 RON Ultimate, one for 95 Premium), or by boost pressue (1 map for say 7psi and one for 12psi). Or am I totally wrong and you tune it a different way all together.
Opinions? Answers?
Cheers all, I value your inputs.
Dave
:burnout:
https://www.sau.com.au/forums/topic/12294-safc-setup-with-adjustable-boost/
Gester:
No, as my car is a series II, i'm aware of the problems running greater than 12psi and as it's a daily driver i will probably set it to around 10psi for normal driving and 7psi for a low boost setting (possibly on normal premium unleaded).
Hippy:
As you are probably aware, the SAFCII allows you to tune in or out fuel as required. I don't think overall, there will be a huge effect of not running a boost controller without adjusting the fuel mapping via the SAFC but certainly an advantage of being able to tune the car accurately for any given amount of boost would not only make a smoother power curve but also bump power and economy up. As I am yet to install or tune either I really couldn't tell you.
Perhaps, one thing I might consider is doing a dyno run on say 10psi with the SAFC off then turn it on, get it tuned and do another. Depends on available time of myself and whoever I get to tune it.
Cheers!
  • 1 year later...
Dave,
Did u have any problems with installation of the SAFC2? My R33 Series II went haywire with dyno results jumping all over and caused engine stalling. I was told that the AFM for series I and II are different hence the wiring may differ.
Did u follow the N4-C terminal drawing with HW-4 sensor type as recommended on the SAFC2 wiring diagram (which shows the same for series 1 and 2)?
What are your settings for the SAFC2?
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
