will do when i get home...
i'm going on a big rejuvenation spree on the car at the moment...
pulled half the dash apart the other day to find some rattles etc....
found a old cd behind the dash from the previous owner (2 years ago :P)
also found a frequency adapter that wasn't being used, from where someone had adapted the standard head unit to australian radio frequencies
pulled about 15-20 metres of unused cables/wiring out of the car.
got a lot more rattles etc to find yet tho :)
Well i'm not going to go to nuts cos it's sunday but it looks like there are three screw that hold the swivle plate but the actual pivot point (which is what I thnk is loose in yours) seems to be behind the mirror assembly itself. And the combination being flimsy things to pull apart and i've lent my body manual out means that i'm not going to attempt this. You'll just have to find out how the mirror seperates from the assembly because i've seen many different set ups from pop off to slide down pop both bottom clips out and slide the top out! I think their is a tutorial on fixing an R33 wing mirror so maybe thats worth a look!
The rest should be very simple = screws and bolts etc. which i'm sure you can handle.
problem with my loose mirror solvered...
thanks Matt!
while i was in there i also fixed my window guides... my window no longer rattles around, and also put a new switch in :rofl:
my windows rattle when they're down, how do i fix the window guides? is it hard? thanks.
thanks Matt!
while i was in there i also fixed my window guides... my window no longer rattles around, and also put a new switch in ;)
No worries buddy! Although I didn't do much but kick you in the arse! :P
Killed two birds with one stone too! Thats a good days work. 1 rattle down, 27 to go hey? :rofl:
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
