Hi guys, I thought I would join the site as I'm considering buying a Skyline. I've been driving a 300ZX (n/a) for a few years now and thought I'd make the switch to the big time. I love my car, but just thought I'd go for something else. I live in Riverwood in South West Sydney and I'm 25, for those who care.
Anyways, I have a car in mind but don't know too much about Skylines, what they're worth etc etc. Can you guys tell me if this is in the right price range? Cheers
Vehicle 1995 NISSAN SKYLINE ECR33 GTS-T
Price $15,990
Kilometres 70,000
Body 2 door Coupe
Colour Black
Interior Colour Grey
Transmission 5 speed Manual
Engine 6 cylinder Petrol Turbo 2.5L (2498cc)
http://www.carsales.com.au/pls/carsales/...icle_id=3228349
Sorry I don't think that link works, the vehicle ID is 3228349 if you want to look.
Cheers
Edited by bulldog
https://www.sau.com.au/forums/topic/123464-new-member/
This LINK works better :dry:
Looks pretty neat to me, although I have my usual doubts about the kms reading (nothing out of the ordinary). Check out the link that Wink posted, it should give you a good starting point.
Best advice I can give is to look at and drive as many Skyline's as possible to get a feel for the car and get an idea on what you get for your money. Don't make the mistake of buying the first one you look at without getting an idea of what else is out there.
Good luck and welcome to SAU :ermm:
EDIT: Liz pretty much bet me to everything I just said lol >_<
https://www.sau.com.au/forums/topic/123464-new-member/#findComment-2280349
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
