Hi everyone,
As the title suggests, i need to sell my R32 GTS4 sedan as soon as possible!
My stagea is on the way from Japan, so i need this gone!
It's a 1989 HNR32 (gts4) sedan, RB20DET (4WD), 5 speed manual, with about 112,000km's on the clock.
It's in great condition, drives very well, reg expires next january.
This car has been very well cared for since i imported it in late 2004. It's mechanically excellent, and the body is also in very good condition with no rust to report anywhere.
Only modifications are a 3" exhaust from turbo back, and an upgraded garrett turbo. The car has recently had a roadworthy certificate done (about 2 months ago), and also has passed EPA testing.
*** Price drop to $9,000 ***
including plates, roadworthy (i'll get a current one once i have a buyer), and reg.
Price is slighty negotiable if it means a quick sale! - Tell anyone you know who may be interested!
Any questions, give me a call 0407 856 896 or email [email protected]
Cheers!
Leigh.
Edited by blackfink
https://www.sau.com.au/forums/topic/123592-sold/
Thanks Blue R32! - Yeah it is very clean.. Wish someone would buy it though! Especially at the throw away price..
Fitzpatrick Speed Works + DRIFTPIG - More photos will be sent to you tomorrow.
https://www.sau.com.au/forums/topic/123592-sold/#findComment-2289846
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
