hi guys this is my very first ? i have a high rise manifold with a T3 turbo ext. waste gate etc etc the turbo seems to squeal when it reaches boost just after she's warmed up when its nice and hot no worries any ideas ?is it fu#$#@ as the whole set up is only 3 months old
https://www.sau.com.au/forums/topic/124194-turbo-squeals-r32/
is it definately the turbo? there could be a very small chance that it is one of the belts (fan, etc) slipping with the sudden increase of acceleration. then once they heat up they are slightly stickier so they grip a bit better. worth a look atleast.
If you can get to your in take tube easily take that off the turbo and see how much end float you have. Just grab the turbo shaft and try and move it back and fourth. There should be a little bit of end float so don't be alarmed if it does move a bit. (Do this when the engine is cold and stopped). If there doesn't seem to be much end float you may have a leaking intake manifold gasket. A easy may to check this is to start your engine and let it idle, get a can of aerostart and LIGHTLY spray it around the intake manifold where it bolts to the haed. if you have a leak it will be sucked into engine and you will hear your engine start to run a little rough and maybe increase in RPM. (Try not to spray aero start any where near electrical conectors eg injectors). As i said you will only need a little bit of this stuff to notice a difference in the way your engine run, so don't just keep spraying it around for the fun of it, as it make's a hell of a mess.
Hope that helps mate.
manifold turbo gasket bro
if ur real unlucky turbo but go with the first 1
have a look around the flange for black shit as a sign leakage
thanks for that ill do that the squeal is actually a screeching sound hopefully its what you guys say it is
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
