Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
Hey Dude,
Can the thermostat be used with other oil filter kits like the HKS R Type filter. It comes with the relocater kit and a core but no thermostat. Can this thermostat fit in with the dimensions of the other kit?
Thanks
Brendan
  • Replies 125
Posted Images
Hey Dude,
Thanks
Brendan
Sure can :)
All you need to do is plug it in line and you're all set
It comes with fittings aswel
Hi N1GTR,
Had a look at the space left in the engine bay...not much.
Can you please post pictures and dimensions of single and dual filter setups. I'd like to see if I can fit either in what space I have before I commit.
Thanks and regards.
Hi N1GTR,
Thanks and regards.
Hi
I dont have sizes for the filters, just have a look at the pic and then have a look at the size of your current filter as all the filters will be about the same size
You have a GTR? Then id suggest putting it either under the car, or in the space where the battery normally is on most cars(i know R33's have them in the boot)
So far no one who's bought one has taken pics and sent them to me, id do it for mine but my motor is in bits being rebuilt
:happy: Steve
just to confirm, if i get just the thermostat and core, it will all fit in and work.. i.e I dont want to relocate the filter.
Hi Suspense,
If you get those parts and dont want to relocate the filter, you wont be able to fit them as the filter has no where to be located on the lines. Have a look at the very last pic attached on post one, and it should be quite easy to understand what i mean
:D
Hi Steve-o, mate i'll grab a filter relocation kit with a cooler and thermostat, you know what i want mate. Virtually everything i need to relocate filter then to cooler via thermostat then back to motor.
No worries Adam
Ill PM you the different configurations you can choose from :D
Hello Guys
I am the supplier for the thermostats here, i am having long delays with theses items from every supplier in Aus.
the cheapest replacment i have found was to be earls which want 167+gst each thermostat. which is far from a joke, i have around 8 coming in the next 2-3 weeks max, they were ment to be here sooner but have been delayed
i know is will make many ppl angry who have already ordered and paid and have been waiting for a while now i am very sorry for the delay and im doing everythign in my power to speed things up
Also if ANYONE can find a better priced Inline oil thermostat for under $120 each please contact me ASAP i will make it worth your while if you can find me 5 items here in AUS NOW which i can get my hands on to please these awaiting customers
you can contact me or steve via pm if you need any more info or help.
once again i am very sorry for the unexpected and uncontrolable delays
Do u have like any time frame when these kits are gonig to turn up? can u confirm when they left and when they should arrive even though its on sea freight surrely someone knows whats going on
hi N1 GTR
you have said that the kit comes with everything needed but how much length do you get with the hose?
do you get a box of pre-made pipes of varying lengths?
or does it come with one role of hose and fittings to be put on to your descression?
i ask because id like the whole kit but i think ill only be getting the relocation kit due to funds and would like to know how much length i would get. id like to be able to mount the filter flat near the battery in a r32 so it needs a fair bit of length in the pipes as other kits i have seen only come with about 30cm of pipes. id then like to mount the oil cooler and thermostat (purchased later) in front of the right hand wheel, basicly short lines from where the filter is to the cooler.
thanks for any help
damien
Mate I need the oil cooler kit my mechanic cant finish my car and has been waiting already 2 weeks for it
cant you send the kit off then the thermostat later when it arrives
Not happy at all ive had no confirmation or anything that my payment has been received either slack as
Please read above, there has been an unexpected delay due to a shortage of supplies.
hi N1 GTR
thanks for any help
damien
Hi Damien, pm will be sent later today with all that info for you
Spandex can arrange this for you, ive emailed him and asked him to do so for you.
I confirmed the money was paid, and i have replied to EVERY one of your PM's.
Speak to spandex about this from now on, he's obviously the person you need to speak to.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
