Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
Hey Dude,
Can the thermostat be used with other oil filter kits like the HKS R Type filter. It comes with the relocater kit and a core but no thermostat. Can this thermostat fit in with the dimensions of the other kit?
Thanks
Brendan
  • Replies 125
Posted Images
Hey Dude,
Thanks
Brendan
Sure can :)
All you need to do is plug it in line and you're all set
It comes with fittings aswel
Hi N1GTR,
Had a look at the space left in the engine bay...not much.
Can you please post pictures and dimensions of single and dual filter setups. I'd like to see if I can fit either in what space I have before I commit.
Thanks and regards.
Hi N1GTR,
Thanks and regards.
Hi
I dont have sizes for the filters, just have a look at the pic and then have a look at the size of your current filter as all the filters will be about the same size
You have a GTR? Then id suggest putting it either under the car, or in the space where the battery normally is on most cars(i know R33's have them in the boot)
So far no one who's bought one has taken pics and sent them to me, id do it for mine but my motor is in bits being rebuilt
:happy: Steve
just to confirm, if i get just the thermostat and core, it will all fit in and work.. i.e I dont want to relocate the filter.
Hi Suspense,
If you get those parts and dont want to relocate the filter, you wont be able to fit them as the filter has no where to be located on the lines. Have a look at the very last pic attached on post one, and it should be quite easy to understand what i mean
:D
Hi Steve-o, mate i'll grab a filter relocation kit with a cooler and thermostat, you know what i want mate. Virtually everything i need to relocate filter then to cooler via thermostat then back to motor.
No worries Adam
Ill PM you the different configurations you can choose from :D
Hello Guys
I am the supplier for the thermostats here, i am having long delays with theses items from every supplier in Aus.
the cheapest replacment i have found was to be earls which want 167+gst each thermostat. which is far from a joke, i have around 8 coming in the next 2-3 weeks max, they were ment to be here sooner but have been delayed
i know is will make many ppl angry who have already ordered and paid and have been waiting for a while now i am very sorry for the delay and im doing everythign in my power to speed things up
Also if ANYONE can find a better priced Inline oil thermostat for under $120 each please contact me ASAP i will make it worth your while if you can find me 5 items here in AUS NOW which i can get my hands on to please these awaiting customers
you can contact me or steve via pm if you need any more info or help.
once again i am very sorry for the unexpected and uncontrolable delays
Do u have like any time frame when these kits are gonig to turn up? can u confirm when they left and when they should arrive even though its on sea freight surrely someone knows whats going on
hi N1 GTR
you have said that the kit comes with everything needed but how much length do you get with the hose?
do you get a box of pre-made pipes of varying lengths?
or does it come with one role of hose and fittings to be put on to your descression?
i ask because id like the whole kit but i think ill only be getting the relocation kit due to funds and would like to know how much length i would get. id like to be able to mount the filter flat near the battery in a r32 so it needs a fair bit of length in the pipes as other kits i have seen only come with about 30cm of pipes. id then like to mount the oil cooler and thermostat (purchased later) in front of the right hand wheel, basicly short lines from where the filter is to the cooler.
thanks for any help
damien
Mate I need the oil cooler kit my mechanic cant finish my car and has been waiting already 2 weeks for it
cant you send the kit off then the thermostat later when it arrives
Not happy at all ive had no confirmation or anything that my payment has been received either slack as
Please read above, there has been an unexpected delay due to a shortage of supplies.
hi N1 GTR
thanks for any help
damien
Hi Damien, pm will be sent later today with all that info for you
Spandex can arrange this for you, ive emailed him and asked him to do so for you.
I confirmed the money was paid, and i have replied to EVERY one of your PM's.
Speak to spandex about this from now on, he's obviously the person you need to speak to.
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
