Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
  • Replies 125
Posted Images
im interested in single filter and thermostat and if u can supply i need a sandwich plate for two gauges,whats availability and price please. i allready have a cooler.are the hoses in kit screw on connections to cooler or hose clamps? i can wait for thermostat but need rough time about when would get incase to long.(want engine back in and running b4 xmas)
thanks.
sorry, how thick?
Approx 3-4mm, i dont have one here though so i cant measure up for you sorry
thanks.
Hi
Single filter and thermostat shouldnt be any problems, ETA on delivery is about 14 days currently, so yeah Xmas should be fine
Send me a PM by the end of the week if you're keen and ill sort it out for you, other than that this GB will be closed >_<
pm sent! :/
Replied ;)
No way I JUST LOGGED ON today to get your pm. Your group bay doesn't officially close til tommorow.
Please send me a B&M cooler, twin filter relocation kit, and thermostat.
How do I pay, please, please, please!
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
