Woo Hoo!!!!! Ultimate 98 in Burnie from 8am tomorrow! Finally!
Had a look at the bowser and it's going to cost $1.57.9 That's 9c dearer than PULP (1.48.9) which is 7c dearer than ULP (1.41.9) here in Burnie.
When I was in Orange(NSW) last week and filled up the renter ULP was 1.45.8 So we're not that had done by here as a regional area!
Any RB turbo deserves 98 whether it's stock or modified! IMHO
I've used 98 on the mainland in both my Skylines and it's well worth the extra $4.50 (@ 9c for 50ltrs here in Burnie) for the benifits I have seen! Again IMHA
  • Replies 58
Wogboy, R u getting better economy and a bit more power?
When I cruise to hobart and back (been down that way afew times in the R34) I 'll average around the 450-480km for 55ltrs.
When I was over on the mainland at easter time (with the R34) got a full tank of 98 in Melb and used it for the 3 weeks I was there and aveaged 500-550km for 55ltrs and the car felt half a gear better!
I love the stuff! Can't wait to run a few tanks thru and get another dyno tune!
You are spot on wogboy- ... being designed as JDM, Japan has much better fuel than we have here in Oz, don't quote me but 98 is the norm. So running on 95, you are right at the bottom of the ECU range. I have 3 engines stuffed purely because of dud fuel.
So the rest should follow your lead, and treat their engines with some respect.
I think given our current fuel status that the oil companies will now phase out 91RON... it is only realy good for lawn mowers and starting fires anyhow.
The pricing is OK. Using 19.95 for booster and 95Ron has us paying 1.84 / litre. See ya soon Rosie, with a trailer full of drums.
TT
Edited by Targa Tom
Ok cool... so now you guys have got 98RON ultimate, here's the next thing to hope for!
http://www.bp.com/sectiongenericarticle.do...ntentId=7016865
and fuel is soo cheap there too - $2.25/ltr when I was living there 6 months ago
TT
Well I just got some at BP Glenorchy, I called in to Hobart (Brooker) but they hadn't set it up yet but told me it would be going in a few hours.
I didn't expect any power increase but I must say it feels a hell or a lot smoother to redline.
I paid 1.54.9
not bad I think.
Cheers
I filled up 3.0R Libery I have at the moment with Ultimate at BP Booker just before - $1.54.9 p/l. I paid the same price for 95RON just four days ago!
I paid 1.54.9
not bad I think.
Cheers
Just filled my R34 with 98 (Yum! Yum!) and what a surprise went down to $1.54.9 was $1.57.9 yesterday!
Took 50ltrs, so that's $3.00 more for the good stuff! (PULP was $1.48.9) Well worth it!
Edited by Wogboy
Its at every site which the exception on BP Newnham and Southbound. BP St Helens won't have it til next week.
As for the price it was going to be 157.9 then 159.9!?!?!? then went down to 154.9. BP had sent through the wrong cost price
I'll try running my baby on 26 psi again and see if it'll handle it on Ultimate, with the right oil pressure, top pistons and the a GOOD driver behind the wheel;) NOT REALLY!!!
Not long now. She should be boostin out of the workshop next week and hopefully it'll make it's first trip down to Hobart for the drifting
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
