By the way I just spoke with Daren Mews with his modded S14 Drift car and he is going to be out there with us, and we will be out together this time for big show down. Keep an eye on your mirrors if out there at same time, althogh probably not.
  • Replies 640
Posted Images
will be good to see Darren again, its been a while....he will need to check out the details in this thread to book and pay.
re the ebay link, those are wet tyres, will only last a day or 2. The price is good and they tyres will be brilliant for 1-2 laps at a time, but not really good value for money when you look at laps per $$
re the kumhos, I've used the V70A but not V700. the V70A was pretty hard for a semi slick, so lower grip but it lasted well. In fact I only used 2 sets for a 8 round season of racing
Darren has already paid and put his entry thru
V70A and V700 are the same tyre, you can get them in different compunds, soft med and hard but the hard is the most common
Is there any way to tell which compound the tyres are by a marking or similar?
Got the details at work but we need a few entrants and a few flaggies.
We can get people $40 CAMS day licences if $85 is too much.
Also, for those of you comparing this price to Wakefield, don't forget that this track is in Sydney so you are spending about $80 less in fuel getting to and from the track.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
