Hi their i have an R33 S1 GTS-T.
Last night when i finished work i noticed when i took off the engine sounded like it was sucking alot of air as i was building up speed. It was fairly noisy than normal and also the BOV wasn't making the same noise as i backed off the accelarator. Also when you stuck the foot into it i noticed a fairly noticeable power loss aswell than normal. It just doesn't pull like usual. Had a quick look at my HKS Pod and didn't notice anything out of the ordinary and also checked the hoses for leaks but came up with nothing. When it was running it didn't run hot at all either.
Any Ideas Guys?
Thx James
https://www.sau.com.au/forums/topic/125096-air-issue-i-think/
Rather sounds like an intake leak. Could be anything along the way after the turbo.. (intercooler piping)
It would give you all those symptoms. The charge-air escaping would be louder than your filter intake sound, and it would give you pretty poor performance as the leak opens up.
Had a very thorough look at all my pipework today except for the exhaust manifold and looked at all the clamps and not one was loose. Today it has started to idle roughly and occasionally stall when pulling up.
Any more ideas?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
