Hey Fella's,
Well in short the problem is located near the fan belt, but definetely isnt. At first thought it was as when cold thought it may have been, and sometimes when load applied it also does it (high pitch squeeling). However, had head under the bonnet and realised it wasnt the fan belt. It's a high pitch squeel much like that a loose/worn fanbelt, but is coming from around the injectors/alternator area.
Anyone with any help or possible idea to what it could be please shout out. Im hoping to get it into a workshop within a week, and seeming i dont get home to after dark i can't see too much.
Cheers
Dan
Edited by DC_GTST
https://www.sau.com.au/forums/topic/125122-mystery-sound/
Not sure, but is there a possibility that it's your timing belt? If an old idler or tensioner bearing seizes up, the belt would slip and scream across them?
It's a wild guess, and not exactly where you're hearing the problem, but might be worth having a look through the inspection plate?
https://www.sau.com.au/forums/topic/125122-mystery-sound/#findComment-2311021
sounds quite similar to mine.. I have removed my timing belt and it's definitely not the belt loose as that would be a big worry. I sprayed some wd40 around the area and it quietened up totally (but came back a day later).
It's either the water pump bearings or the timing belt bearing getting old and squeaky (it obviously wasn't replaced with my timing belt :P). I dont't think its fatal, but I'm definitely going to be looking at replacing my idler bearing and tensioner sometime in the next 6 months. I'm guessing that its not really possible for the bearings to totally cease overnight, but it could be an expensive mistake if I'm wrong.
https://www.sau.com.au/forums/topic/125122-mystery-sound/#findComment-2311038
Yes it would be expensive as the rb's are intereference motors. :thanks:
While your replacing the tensioners/idlers grab new studs for them from nissan for $2. Well worth while as the studs have been known to let go.
Also.. the idlers are stupidly priced, use 2 tensioners. The tensioners are locking so there's no problems there.
All the RB tensioners are the same (rb30,20,25,26) holden are slightly cheaper BUT they only run one bearing inside the shell compared to nissan that run 2 side by side in the shell. Thats holden for you. :P
or head down to CBC and have them match a bearing up, from memory the bearings are $30.
https://www.sau.com.au/forums/topic/125122-mystery-sound/#findComment-2311430
Bearings Industries was the other go... There is a big thread on it, and has their contact details. Both bearings cost me under $100 in total.
And fair enough, pred... it may not have seized, it could just be a whinger! In any case, DC... get it checked when your car gets booked in. =-]
https://www.sau.com.au/forums/topic/125122-mystery-sound/#findComment-2311520
In that case then,check to see if the teeth have worn down.very risky driving if that is the case...I think that it is just a slipping belt give all the fan belts a tighten up..';
When i got the car back on the road.I never had any air con for the 1st month and when i got it i9n the first 30 mins of driving with it on it started a super high pitch sqweel.It freaked me out and the peeps next to me....
All i did to remedy it was line the inner side air of the con pump fan belt with dry soap and re-tightened the belts.Now no sqweel.
https://www.sau.com.au/forums/topic/125122-mystery-sound/#findComment-2312327
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
