Hey guys i need some help here
ive got cracks in my exhaust manifold (its a TRUST manifold)
does anyone know any good Zorst places that can look after me or where i can get a new manifold (Brand new one from trust is almost 4,000 dollars)????
and has anyone had similiar problems with a Stainless STeel Exhaust Manifold?????
https://www.sau.com.au/forums/topic/12528-help-cracking/
I woudnt go taking it to the average exhaust shop. Take it to a business that specialises in Tig welding and can do X-ray quality welds. Any company that does pressure piping. vessels etc or boilers etc. These people are qualified welders and will be able to fusion weld your manifold, or if they need to use a filler wire they will know the correct grade filler wire, though the Japs do use grades of stainless not easily purchase in OZ. At a rate of about $50-75 / hour you should be able to get it fixed for less then $150
Most exhaust shops would fall over themselves if asked to do a purged weld that would pass a tensile test etc. Welds should be stronger then the parent metal due to the localised heat treatment around the HAZ (heat affected zone)
As for stainless manifolds being prone to cracking, well i dont totally agree with this. It may be the design , but more likely the fabrication that causes the problem.
Grab a metallurgy text, mild steel relies on large corrosion factors to get the job done, hence the wall thickness and need for multiple passes when welding.
Many grades of stainless steel offer better temp properties, lighter weight, higher tensile strengths. Remember even steam bends are by nature used in water and gas systems, with much higher pressure then an exhaust manifold, but not very high temps. Saturated steam at say 450kPa is only about 135 degrees.
Some locally made stainless exhaust manifolds made from 304 stainless (about the cheapest grade and not all that suitable for high temps over 300degrees) can have probs, but if braced should still do the job if fabricated correclty.
Stainless 321 would do the job better and is available in plate and tube so lends itslef to manifold construction, albeit at a higher cost.
https://www.sau.com.au/forums/topic/12528-help-cracking/#findComment-230237
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
