Hey all,
Well about a week ago my ABS warning light came on in my R33 GTS25t. I thought it must just be the pads need replacing, as I know they were getting low. Anyway, I've had a look and the pads seem ok for now, so I thought I'd try an emergency brake. The wheels locked up, so my ABS is caput...
Brake fluid level is fine..
Could it be wheel speed sensor related, or is it the actual ABS unit? If so how much are parts to replace/repair? I don't know a whole lot about this..
Cheers :)
https://www.sau.com.au/forums/topic/125473-my-abs-is-bunged/
hay man it must be the week for abs
also to this thread my abs light came on this morning and now i have brand new breaks and also the fluid is still in the zone of narly full but have now toped it up.
also so on the way to work i did a abs stop from 60 and i got some still but not as hard as normal when the abs kicks in
so to jump on your thread
Hey all,
Cheers :thumbsup:
.. try check all ur fuses under the bonnet. i had blown fuse once which caused abs light to come on..
Edited by dezzabye123
Yo guys, I had exactly the same prob with my ABS.
Checked fuses, I've got PFC so i couldnt check diagnostics.. Checked sensors, everything. Ended up being a busted ABS module (The thing in the top right of your engine bay with all the lines running into it)
I got a replacement off someone on SAU for $80, and got a brake place to fit it (cost about $50).. Good as new!!
Just make sure to check the model number of the replacement before you buy it! Keep an eye out for wrecking R33 threads, and post a WANT TO BUY ad in the WANT TO BUY section :P
Good luck!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
