bombastic, is that city driving? or highway? or both?
how are you finding that solenoid boost mod? big difference in performance?
IIRC it was all in the suburbs/city.
When I first did the mod I thought it was a fairly noticeable difference, now I'm just used to it, so I'm waiting on a turbotech boost controller to bump it up a little :D
I don't see why performance should chew up heaps more fuel, unless you get on the boost every time you take off. Even then, you're still only accelerating to the speed limit and then cruising - what difference does it make if you burn fuel at a high rate for a small period of time (neglecting running rich on boost etc.), or at a low rate for a large period of time (like a grandma)? Either way, you should have a similar amount of energy being converted into motion and heat to get to cruising speed. Of course if the next set of lights go red then I can see how it'll be a big waste.
Excuse my skewed and probably-wrong theoretical world view :dry:
Mate i got a stock 33 s2 only mods are exhaust and pod, i constantly get 450 to 500km per tank, but thats before the light comes on, i did get 520km once just as the light came on, then filled up, still had around 5-8 litres left in tank. I don't boost it much manly drive just to work and back and occasionally weekend fang.
have been getting 300ks to a tank for a 200rwkw 4 door r33s1 (yes, they do have fuel lights)
been better since i cleaned my afm, and use 5th gear a bit more
getting 350+ now to a tank (turned o2 sensor back on on pfc)
getting retune down the coast, will be stoked if i can get 400ks to a tank
does it involve alot of highway k's?
coz i get like twice as much if it's highway.
Yeah, sometimes. Although its only for 15-20mins as work is close to home. Don't see much of a change when just driving around town, maybe closer to 450km a tank. I find if i don't boost it much then the fuel lasts alot longer, and besides around town or anywhere for that matter on the street you really don't need to boost it anyway, but then there's the track, where at wakie a few weks ago i went through 3/4 of a tank for the day!!! only did like 250kms!!! Can't wait to see what it uses at Eastern Creek ;)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
