R33 turbo 5 speed gearbox in perfect condition. bought as spare gearbox now must sell never used, never seen big hp. built other gear box with ppg dog gears so no longer need my spare gear box.
$1650
please contact me on : 0404479491 peter
email: [email protected]
this has been sold please delete :pirate:
  • 4 months later...
