Okay people, i have stock r33 GTS-t S2, went to track day down at wakie and all went well. come home car was all good, a few days later the car started to idle rough, idling down to 500-400rpm, kept running though and hasn't stalled. When i pressed the accelorator car was fine, didn't miss had good power still. I changed the plugs which looked like shit and thought maybe that was the problem but no, idle still rough. I have noticed that when i change gear sometimes or back off sometimes i get popping in the exhaust. Never run the car below just under quarter of a tank of fuel and always premium at worst. Actually since trackday only run BP ultimate. Car isn't running hot or anything just rough idle. I did turn the idle up a smidge and seemed to fix it but it has come back. i don't think turning the idle up is my answer.
It doesn't seem to be running lean as fuel usage is about right.
Only mods i have are, dump pipe and 3inch exhuast and pod filter, i do have a dual stage boost controller installed but its set on stock 8psi when i'm on the street, when i'm at the track i'll turn it up to 10psi but at wakie it played up and overboosted so left it on 8psi.
Any suggestions??
Maybe fuel filter, pump maybe, even a leak?? Don't know, thats why i'm asking you.
Cheers Adam.
https://www.sau.com.au/forums/topic/126048-rough-idle/
take the AAC off and clean as well Adam ..
other option is the TPS might need a little adjustment
:yes: WTF???
Okay sorry should of mentioned i have cleaned the AFM friday before trackday, so two weeks ago today. Chris what is AAC and TPS, and how do i clean them.
Okay Chris don't answer that i'll do a search mate, might pick your brain later though if this don't work, maybe even have a look at it for me??? be much appreciated.
https://www.sau.com.au/forums/topic/126048-rough-idle/#findComment-2329792
haha ok .. TPS is easy with a 6mm socket .. its the throttle position sensor, on the throttle body -- may be a bandaid fix though
AAC - auxilery Air control (idle control).. big DIY on how to clean them on here..
Thanks Chris, i'll be doing this tomorrow. :yes:
http://www.skylinesaustralia.com/forums/in...mp;hl=ACC+clean
https://www.sau.com.au/forums/topic/126048-rough-idle/#findComment-2329878
Okay cleaned my ACC but noticed i had a leak in a small hose just above the ACC valve after i cleaned and replaced it, don't know if i broke it while i was fiddling with the ACC or not, but fixed it. As for the main problem being fixed i don't know, on the sticker under the bonnet it says to set the idle at 650rpm, so i did and it seems to hold idle now but occasionally it 'misses' i don't think it is missing but i don't know how else to describe it. Might be time to get a tune from a shop.
Anyway thanks for those who responded, i did actually learn somethings about my car. I will post when/if i find out what/is my problem.
Cheers, Adam.
https://www.sau.com.au/forums/topic/126048-rough-idle/#findComment-2331024
Chris thanks mate, i owe you :D
Okay it seems to be all good now, nice and steady idle. If it was the hose that was broken before or if the ACC valve needed cleaning i don't exactly know which was the problem but both have been done and now she idles like a kitten. :P
https://www.sau.com.au/forums/topic/126048-rough-idle/#findComment-2334167
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
