Flying Performance International is the only official online Hybrid & SABER dealer
Flying Performance International official website www.flyn.com.au
Check out the Hybrid & SABER official website at www.powerdigger.com
FLYING PERFORMANCE 3" DUMP AND ENGINE FRONT PIPE IN ONE, because it is a Flying 3" mandrel bent dump & front pipe in 1, not just the front pipe that other people sell, WE GUARANTEE MASSIVE POWER INCREASE OF UP TO 50 PS!!! If you have a boost gauge you can see the 2-4psi improvement and the better throttle responsiveness. VERY LIMITED STOCKS! HURRY!!!
We have the following models available:
s13 / 180sx ca18det
s13 / 180sx sr20det
200sx s14 / s14a / s15
r32 2.0L gtst / gtsr
r32 2.5L gtst / gtsr
r33 gtst / gtsr
$225 delivered
OPTIONAL PACK
FLYING PERFORMANCE NEW 6 METERS HEAT SHIELD EXHAUST WRAP KIT INCLUDING STAINLESS STEEL RACING CLAMPS $35
This pipe will give you 2 - 4psi increase depending on existing boost pressure.
Payment Instruction
Postage & Handling = $15 freight Australia wide
PAYMENT TO : FLYING PERFORMANCE INTERNATIONAL PTY LTD
ST. GEORGE BANK LIMITED
BRANCH NO. : 112-879
ACCOUNT NO. : 065766824
PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order!
After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details.
Once we receive your payment, we will inform you and send it at the same time.
It will be packed and sent securely in boxes or bubble padded bags for best protection.
Optional extra
7f_1.JPG $48 SABER stainless steel mesh air filter
41_1.JPG $180 SABER 60mm electonic smokey lens gauges
59_1.JPG $259 SABER GDB WRX /STi air intake kit
cf_1_b.JPG $49 HYBRID a set of 10 HOSE CLAMPS, 2.5", 2.75" & 3"
f0_1_b.JPG $19 HYBRID SILICONE HOSE REDUCER, We have 3" - 2.75" / 3" - 2.5" / 2.75" - 2.5", you tell us the size you want.
0a_1_b.JPG $17 HYBRID SILICONE HOSE, 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" STRAIGHT HOSES
53_1.JPG $7 FLYING SILICONE VACUUM HOSE
12_1.JPG67_1_b.JPG $49 Flying bov
05_1_b.JPG $49 Flying boost controller
7b_1_b.JPG $29 Flying boost controller
5c_1_b.JPG $199 + $25 extra freight
4e_1.JPG $33 FLYING 6 meters EXHAUST HEAT WRAP
06_1.JPG $149 Flying sr20det turbo manifold (SOLD OUT)
0a_1.JPG $189 Flying Rb20det / rb25det turbo manifold
dd_1.JPG $149 Flying 180sx s13 r32 300zx camber arm
e3_1.JPG $149 Flying s14 s15 r33 r34 camber arm
b8_1.JPG $139 Flying GT wing
72_1.JPG $99 Bee*R PINAPPLE BUSHES S13 180SX S14 S15 R32 R33 R34 Z32
5d_1.JPG $75 FLYING S13 180SX S14 SR20DET SILVIA SHORT SHIFTER
26_1.JPG $79 FLYING SILVIA S13 180SX S14 S15 SR20DET TURBO DUMP PIPE
fe_1.JPG $99 FLYING SKYLINE R32 R33 R34 RB20 RB25DET TURBO DUMP PIPE
55_1.JPG $55 FLYING ADJUSTABLE FUEL REGULATOR
7b_1.JPG $25 FLYING OIL CATCH CAN
HSD Suspension
HSD coil-overs are used by 2005 Drift Australia champion Darren Appleton and many other prominent drivers in Australia. Now available only in the premium HR series, HSD coil-overs feature 55mm heavy-duty full-tapped dampers with 15-step damping adjustment. All models feature pillow-ball top mounts for easy installation and maximum control. Models with strut-type suspension also feature camber adjustment, while all models feature adjustable base height and spring seat height.
HSD coil-overs are supplied with spring rates intended for club-level motorsport, drift and street driving. Harder or softer springs are also available at just $100 a pair. All rates from 3kg/mm to 14kg/mm are kept in stock.
All HSD coil-overs come with a 12-month warranty against manufacturing defects.
NISSAN
S13 Silvia or 180SX $1549
S14 200SX $1549
S15 200SX or Silvia $1549
R32 Skyline GTS & GTS-t (GTS-4 available to order) $1549
R33 Skyline GTS25 and GTS25t $1549
R34 Skyline GT and GT-t $1549
R32 GT-R $1549
R33 GT-R $1549
R34 GT-R $1549
Z32 300ZX and Fairlady Z $1549
Z33 350Z $1549
TOYOTA
JZX90 Mark II, Cresta, Chaser $1549
JZX100 Mark II, Cresta, Chaser $1549
JZA70 Supra (Also GA-70, MA70, MA71) $1549
JZA80 Supra $1549
SXE10 Altezza and Lexus IS200 **NEW** $1549
SUBARU
GC8 Impreza WRX (MY94 to MY00) $1599
GDB Impreza WRX (MY01 to MY02) $1599
GDB Impreza WRX (MY04 on) $1599
SG5 Forester $1599
MAZDA
FC3S RX-7 (Series IV and V) $1549
FD3S RX-7 (Series VI to VIII) $1549
MITSUBISHI
CP9A Lancer Evolution (IV to VI) $1549
CT9A Lancer Evolution (VII on) $1549
HONDA
EG Civic $1549
EK Civic $1549
DC2 Integra $1549
DC5 Integra **NEW** $1599
AP1 S2000 $1549
Edited by [FLYN]
This wrap will work on any make or model of cars, if you can wrap it you can use it! This wrap can even eliminate turbo lag!
You have seen it in proper race cars like V8 Supercars and JGTC in Japan, and now we bring it to the street, introducing the FLYING Exhaust Fiberglass Wrap. It is a weave of the finest insulating fiberglass material with extremely closed texture pattern. The type of fiberglass we are using to make the Exhaust Wrap is carefully examined and tested in our overseas development centre to ensure it will last over the vehicle's working life for reliability and durability. It keeps the heat in the pipe and at the same time protects the electronic components in the engine bay.
The wrap is about 2.5 millimeters thick and 1.8 inches wide, can withstand temperature of up to 600 degrees Celsius which is something that the HPC won't be able to offer. Keeping exhaust heat inside your exhaust pipes maintains exhaust gas velocity, helps to increase combustion scavenging and thus increases power. FLYING Exhaust Fiberglass Wrap can also reduce under bonnet temperatures as much as 80% by insulating both fuel and clutch lines, while protecting mechanics and other electronic components in the engine bay from injury. For example, 6 meters long is enough to wrap a 200SX / Skyline GTS-T DUMP AN ENGINE FRONT PIPE IN ONE easily. The 2 clamps that come with the 6 meters wrap pack are used to keep the wrap in places after you wrap the pipe, one clamp for each end.
If you need extra clamp, they are AUD$2 each
The wrap is about 2.5 millimeters thick and 1.8 inches wide. It can be used on dump pipes, front pipes, exhaust turbo manifold, air intake piping and also intercooler piping.
HSD Suspension
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
