Hello,
Just had a discussion about Garrett Turbo's vs HKS
Who ever has any links please post here
This thread was started because a Turbo marked Garrett 707160-9
is being stated as a Hks gt-ss but this link,
http://tuneagent.com.au/public/content/Vie...gory.aspx?id=85
says its the 707160-7 .
Is this like the great Japanese 206kw di-barkle?
This will also help others make decissions.
https://www.sau.com.au/forums/topic/126095-turbo-identifications/
Im not 100% sure what you are getting it...
Either way, there is TRUCK LOADS of info on these forums, search button works if you even just put the turbo ID tag numbers into the search engine they have been discussed that much :)
http://www.skylinesaustralia.com/forums/in...=80624&st=0
http://www.skylinesaustralia.com/forums/in...amp;hl=707160-7
If you wanna look @ the other dozen or so results, here is the search link:
http://www.skylinesaustralia.com/forums/in...ite=%2B707160-7
If the Garrett Items come to 1.5k each (which is over-priced)
Its a line-ball call as its almost cheaper to purchase GT-SS from Japan for $3300 landed.
If you have an issue, please post in one of the other threads, we dont need another on the GT-SS and the equivalent Garrett offering
Cheers :glare:
Guest
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
