Pivot - Speed Meter X [Speed limiter cut, and Gtech timer]
Guest mooks66
Hey guys, my trusty little Pivot speed meter X is for sale, its in friggen marvelous condition.
what it does?
-LED speed readout (0-350Km/h)
-Speed limiter cut for all Japanese vehicles
- Automatically records time to distance (0-100, 200, 300 & 400m) GTECH timer
- Interchangeable between cars
- Peak hold Km/h readout
hooking it up is a sinch
12v power, Ground, Accessories, Speed sensor.
done. exactly as you would hook up an rsm or a tacho for that matter.
attatched are photos, its absolute miniture too :P
My uncle sent it to me from Japan for my birthday present 3 mths ago. Im over it
Retail is just under $300 once converted.
Highest bid over $150 can have it. - on one condition, - you are never to tell my uncle that i sold it or else he'll chop mi balls hahaha
thanks boys.
any qn's just ask
Photo photo 2 photo 3
drop me an email or pm me
  • 6 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
