  • Replies 143
Errr why did you sell your cat-back for??? Blitz is just as fine. Exhaust brands doesn't really make a difference for me. It's just a thick pipe :dry:
Apparently different brands have their unique way of wielding which people believe might make a difference in power. I really don't think it makes much difference.
When you have had a blitz system on your car, id like to hear your response to that...
They are not all the same. This thing was great flowing but with flow comes noise.
Edited by PAV34
clear is much better! did u do the front aswell i go shit comp cant see it
any1 wanna buy my front bar PM me not bad 2 cracks :ermm: dw black stuff is texa will wash off as it was going 2 be cut to fit other car but dont wont to cut it anymore
i put my clear indicator lights on. i was pleased.
but ill let u decide.
after:
what do u guys think??
Looks great, yes it is an improvement. Your R34 looks :D. Looks quite low, what is your ride height? What suspension/springs/shocks do you have? Are they 19" or 20" rims and what offset?
Out of interest, what cat back system are you all running & do you like it?
I have Apexi 3" cat back and it is quite as, maybe a little too quite. :) I brought the car like that so dont have any comparison. I am wanting to add a dump pipe from turbo to cat, any suggestions? It is an R34 GTT sedan.
Looks great, yes it is an improvement. Your R34 looks :). Looks quite low, what is your ride height? What suspension/springs/shocks do you have? Are they 19" or 20" rims and what offset?
hi
thanks :D , i think the clear lights make a major difference.
funny i wish it could go lower!! im sitting on legal limit 100mm. I think the wheels take a big part on my ride!
i have 19" but not sure of the offset, i cant go any lower (maybe on the rear :mad: ) due to the inside guards rubbing on bumps. The tyres are 235 @ front & 275 @ rear. so its tight.
cheers
steve
i have 19" but not sure of the offset, i cant go any lower (maybe on the rear :huh: ) due to the inside guards rubbing on bumps. The tyres are 235 @ front & 275 @ rear. so its tight.
cheers
steve
I would love that set up!! Perfect. I dont want to go lower that 100mm though cause I want to stay legal, dont need the hassles. Do you compromise on comfort being so low?? The 19" look ace, I want ROH Vapors in 19"!! :blush:
Yeah it makes it easier to drive knowing its on legel height, plus the exhaust just needs to be tucked up as close to body as possible. Thats all i did.
its still a comfortable ride, considering i drove a VL holden for 6 years b4 i bought the 34. it sometimes rubs on the inner front guard a little when driving fast around bends.
but a swaybar upgrade could be a solution :ermm:
i love the power of these cars
it makes me feel like dancn :PBJ:
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
