Hey guys got some 32 GTR spares I need to get rid off....
Rear bumber bar with reverse lights- $150 SOLD
Side view mirors. gun metal grey - $50(each) SOLD
Starter motor - $150
Rear drive shafts - $100 (each)
Boot interior trim-$70 SOLD
Door trim - $150 each
0416 255 683
Edited by GTR090
https://www.sau.com.au/forums/topic/126769-32-gtr-spares/
Also got other random bits:
left door rubber
black piece dat fits under/in front of the windscreen
brackets that border around the windows(driver and passenger)
Windscreen wipers
Roof lining inside
https://www.sau.com.au/forums/topic/126769-32-gtr-spares/#findComment-2352076
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
