i think the knock sensor is a factory peizo microphone type thingy that measures DB levels. I assume the PFC is similar to a Link in that you can set the knock sensitivity level, and anything over this level gets registered so you can monitor any bad stuff that you couldnt normally hear when your "up it".
I'm not sure if "knocking" and "pinging" are the same thing. Maybe someone else could expand a bit more for us all.
https://www.sau.com.au/forums/topic/12681-knock-level/#findComment-233425
My car isnt tuned to well at the moment so i keep a good eye on the knock sensor (the little bar and the peak figure).
Here is what i know. Firstly providing you have an option set (cant remember where it is, i think it is in the menu where you select yes and no in japanese) in that menu then if the knock goes above 60 it will flash the check engine light. I have been told 60 is BAD but if you see it peak up around 30-40 it wont kill your engine (providing you dont see 30-40 all day everyday) but repeated excursions to that amount of knock wont help the engine.
I know that there is a person in this forum who is a total gun with the power fc. He could tell you more, i just dont know his nick.
https://www.sau.com.au/forums/topic/12681-knock-level/#findComment-235275
Yavuz from Unigroup suggested to me that anything under 80 wasn't terrible as long as it wasn't all the time. We re-tuned my PFC a bit richer under load and it only dropped a couple of hp so now even on shit 96 fuel, it never gets past 40.
Adrian
https://www.sau.com.au/forums/topic/12681-knock-level/#findComment-236479
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
