Im selling my work cr emotion wheels, im in Victoria
All wheels have no gutter rash and are in perfect condition Pearl bronze...."a little dirty though"
Still have most stickers that came with them, but not on wheels
Tires are approx 70-80% tread.......im no tire person though
The wheels have been on a R32gtr
Im after offers around the $3500
The wheels have a separate insurance on them and are insured for a value of $4500
Edited by Sico04
Insured for that much you'd almost hope to get them stolen...Don't take this the wrong way but I think you should consider the retail price when selling second hand goods you may get more interest.
i did a bit of searching b4 i advertised and didnt find any thing on a current price for the wheels
6 months ago i called one wheel and tyre retailer and they quoted me just over 4k to buy the same rims same size...etc
how bout instead of telling me how im asking too much if any one is interested in these rims PM me with a price they are willing to pay...........
