  • Replies 43
Posted Images
car could easily run high 11's.. was running low 12's but that is on some crappy rubber and very shit launches.. only been out there once..
with semi slicks and the right launch, it could easily get into 11's
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2396444
yeah it is at the wheels.. yeah dyno sheets i will show you.. it was tuned by unigroup so they well i think are the best tuners in sydney, and tuned it safely.. will scan dyno sheet in for you
been holding up perfectly fine for 8 months no hiccups or anything..
the blocks are solid
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2402993
$200 Spotters fee for whoever refers the car to friends and they go through with the sale.
This is free cash for whoever refers their friends to buy their car.
So go on tell your freinds and get 200 bucks for free if they buy the car
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414010
peak of 1.2 bar which is 17 psi. So it normally sits at 1.2 - 1.3 bar to get that much power, with the hi flow turbos they are all not the same, so Unigroup have told me that i have got one which is pulling more punch since they have tuned it safely and reduced the power just in case, but it could easily go to 270rkw they say.
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414648
Keeper: splitfires does the job so well
and i recapped the plugs it .69 but that is all
splitfire helped so much..
dazz: side skirts came with car when my mate purchased these ages ago, so i assume these come from japan
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2462410
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
