Hi - someone has damaged my lovely stag whilst parked outside my house! As well as modifying the driver's side body work, they smashed the corner tail light.
How available are these parts - I'm in the UK?
Any idea how much they cost?
Are the series 1 & 2 interchangeable?
cheers
John
https://www.sau.com.au/forums/topic/127079-series-1-tail-lights/
That sucks!
I believe the series 1 and 2 are the same shape, but s2 has clear indicator lenses instead of orange.
Not sure how hard it will be to source parts, but there are a few of us here who are hoping to replace their s1 taillights with s2 ones, but it all depends on the prices we can obtain for the update taillights (we're yet to find out).
cheers for the info guys - I only need the driver's side corner lens - the bit on the tail gate is fine - if anyone hears of spare ones going - let me know if possible - I'll stick with the series 1 - be a lot cheaper I think.
thanks again
series 2 will fit..... they require minor re-wiring.....
japanese auctions is also possible... corner lens are very reasonably priced for s1.. and plenty... im sure zac at slidewize can help you out.... he accepts paypal also...... shouldnt cost u much at all
Edited by muck
try yahoo auctions from the sliwiserimports link on the stagea section. Still cheap for you since your currency is pounds. let us know whats your outcome.
Getting a set might be cheaper option for you and just keep the rest as spares.
Edited by stasis
Thanks again - great response - really appreciate it. Terminal - if I can't find a solution quick I'll talk to you about your set - won't hurt to have some spares anyway! I'll let you know what turns up. :P
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
