Hi
I am currently in the process of building an engine RB30/26 combo. What I have discovered is that the only brands apart from the jap brands BIG $$$ is the ARGO and SHALLAK versions which cost around $2,600 a set which is still bloody expensive. I have been in contact with a workshop with a good reputation in builidng race engines and we have decided to see if we can try and get a suitable rod out of whats already available. What I am after the rod length of the followin stock rods:
* RB20DET Rod
* RB25DET Rod
* RB26DETT Rod
*RB30ET Rod
The rod length must be exact and from middle of gugoen pin hole to journal hole. We hope to be able to souce rods good for around 600-700HP for around 800 a set even a bit more will be worth it compare to 2,600 for the aussie ones and 4,000 for the jap ones.
GR8NES
  • Replies 53
Yes, up until recently they haven't been making them, but I believe they are now available. Previously the US market has only been after rods for SR20's and VG30's, but now Skylines are starting to become more popular Eagle has decided to make rods for them to.
See'ya:burnout:
Hi guys, if you check the measurements of the standard rods you will find that they are very, very close to the sizes of some very, very common conrods that you can buy, off the shelf from a large number of suppliers. No they aren't made for Nissan's, something much more common in the home of good conrods.
Don't fall into the trap of matching the little end to the standard Nissan gudgeon pin. Aftermarket pistons have the "right size" gudgeon. And remember that Nissan have a variety of big end bearing thicknesses, so you can make minor corrections in the big end journal dimensions as well.
I am looking forward to having this data in the public domain, so good hunting................
Try cunningham rods in the states they do anything rod sizes and they are mega serious rod. they have special patent design and are suppliers to alot of the lemans team. so they can't be that bad. also i think mine cost under 2k
I have found out what rods can be used, they will require very small modifications and they are good for around 700-800HP and cost around $899. The pistons used are RB30 pistons with the pin size to mach the rods. Sydneykid am I getting close????
GR8NES
How's your venture with the rods going?
I'm interested to know as well cos i have an RB30 block and crank sitting in the garage doing nothing... i don't have rods or pistons so i also need to know what specs i need!
Cheers,
Andrew
I learnt that the V8 Chevy Small block 6" Small Journal rods can be machined to fit, I am still deciding which path to take since they are rated at 800HP for eight, then that makes 100 per rod which in an RB means 600HP at the flywheel, I am aiming for closr to that at the wheels, I am able to get a set of RB30 Carrillo Rods for 2,400 which will take 800HP and 9000rpm quite easy. Unless someone else has used the SCAT, Eagle or equivalent rods with success at say 600HP at the wheels with proof I might bite the bullet and go the Carrillos.
GR8NES
yeah $2400 for rods seems HEAPS!!!
i'm looking for around 300rwkw, but would like to build the engine to cope with 600hp at the wheels as well incase further down the track i decide to upgrade the gearbox and go for big power!
are the chevy rods fully prepped, eg forged/linished/shotpeened or what ever is done to make strong rods?
cos maybe you could get those rods and have them strengthened further... like chryotuff :P
Well they are fully prepped and Cryo Tuff may strengthen them further but not sure. 2400 is cheap for Carillos ARGO's are around the same money and NIZPRO quote $3600 for Carrillos they are the best you can get for a street engine. May be if we ask for two or more sets we can get a discount ????
GR8NES
sounds good to me!
$2400 is fairly pricy, especially as i'm not going for 600hp at the wheels... what do you reckon the chances are of getting them under $2k? :P
maybe those chevy ones will tie me over till i need more power, then i can pull out the rods and put in better ones. Then there's the other side of the coin. $900 for the chev ones or $2400 for the carrillo ones, it's gonna cost me $1500 to do the change over down the track anyway, even if i do most of the work myself!
600hp at the engine... what would that translate into rwhp?
GR8NES
GR8NES, can you confirm that the rods to suit an RB25 are 6"? What are the exact dimensions. Also what Chev block is it that uses these rods that are the same size as the RB ones? Sorry, these are alot of questions, but if one company makes them (chev rods) - alot of companies will make them, and from what sydneykid was hinting at, I will bet that there is a company out there that makes the right size, at the right hp rating, and the right price - just not under the nissan tag.
Sorry there are a few questions here, but I wouldnt mind doing a bit more research myself and then post up any results for all to share
Cheers
Steve
Just did a bit more research after asking those questions. Chev 6" rods are used on the 350 and 400 - are these the ones we are talking about GR8NES? Cos if so, I will shoot an e-mail off to carillo and get the low down on the rating per rod, and the cost.
Cheers
Steve
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
