yes there heapz about this on the forum just search. If hicas is on i dont think the car would be working fine, you would loose hicas hence power steer. Its probably disconnected from the hicas unit in the boot, low pwr steer fluid or speedo issue, like speedo not working. Those are the main causes i think otherwise its a bit of a bigger problem.
https://www.sau.com.au/forums/topic/127115-please-help/#findComment-2348913
Yeah thats it My speedometer isnt working it stoped at the same time the light started to come on.
I pulled th dash apart to try fix the speedo but couldnt find anything wrong???
Help...
what does that mean where do i search im only new at this forum
https://www.sau.com.au/forums/topic/127115-please-help/#findComment-2350131
