Group Buy: Goodridge Braided Brake Lines
We are holding a group buy for Goodridge braided brake hose kits.
We have enough people do go ahead with this group buy - if yuou want to be included please make payment before August 4th to make sure you are included.
All kits are $299 each+ $10 Express Postage.
Delivery would take approx 7 days from the cut off date + 1-2 days for AusPost Express post.
These are genuine Goodridge kits which come with all necessary components to install.
They made in Goodridge’s UK factory.
These kits have a life time warranty and are ISO9002, TUC and TOT (UK equivalent to Vic roads) approved.
Goodridge stainless braided brake lines are ADR APPROVED, meeting the requirements of D.O.T. and T.U.V. making them street legal for use on any road in the world.
Pictures here: JustSR.com - Goodridge Brake Hose kits
Why use braided brake hose kits?
Whey eliminate sponginess under heavy braking
Increase braking efficiently
And are abrasion and corrosion resistant
They come with full instructions for install.
Available to suit:
180sx
Silvia
S14
S14a
S15
R32 GTR
R33 GTR
300zx Z32
GTiR
RX3
Want them for another car? Ask and we will find out.... :wave:
If your intersted you need to comfirm your inclusion with me and have paid by the cut off date August 4th.
Please email or pm me with any questions.
Thanks!
Greg
PS also just landed more Bosch 040s, still only $230 each!
Edited by shy180
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
