Hi just chasing some 17s or 18s ive posted in the for sale section too but just thought id check with you guys too .. do u have some ya wanna sell or know of some that will suit the Stag?
Cheers
Lee
Hi :rofl:
I have 18" Ozzy Racing Mags on mine... if that helps.. :yes:
Sorry not for sale lol
https://www.sau.com.au/forums/topic/127167-17s-or-18s/#findComment-2355367
hahaha Cheers StageaGirl, can see your gone get on just fine!! :( n welcome ... i saw ur other post will be good to see u n ur lil one at the photo shoot :(
Lee
PS I finally got some new rims yesterday yay!!!!
Edited by STAGE-A
https://www.sau.com.au/forums/topic/127167-17s-or-18s/#findComment-2356395
i spotted you yesterday at bob jane and other wheels shop at mindarie Lee, was gonna say hello but it was pissin down with rain and cold as hell, plus i was in the bunky anyway :P
post pics mate i wanna see what ya got.
ill try get some pics up tonite :cheers: .. i didnt see ya mate, where were ya?? hahah yeah was trying to bargain between the 2 ..didnt get very far hahaha :blink:
Lee
https://www.sau.com.au/forums/topic/127167-17s-or-18s/#findComment-2357624
