ok guys got a few things for sale and pics to go with it.
im in Carramar near fairfield in syd but would be happy to send them interstate aslong as u guys pay postage.
set of 4 16inch stock s14/r33 rims with 3 tyres that might get u home and one that definately wont.
rims are in nice condition though, dont have pics but can take some if need be.
$200
3 inch rb20/25 dump pipe $50
10 psi actuator from gcg with universal acuator plate
actuator was $130 from gcg plate $20 from just jap.
once again only used for 5 minutes which is pretty obvious from the pictures.
$100
std r32 intercooler with no piping $20
so yeah if u see anything u want pm me here cause i look here quite a bit or if you are really keen my mob
is 0404357336 and my name is Declan :laugh:
Edited by ODessA
https://www.sau.com.au/forums/topic/127483-various-parts-for-sale/
come on guys im almost rid of it all :D
would the acuator suit a t3/4 turbo.. i recon i could get it working.
if so then im very interested. pm me a price + posted to tas.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
