:D I can't stop thinking what the hell is going on, my left door got a paint scratch and I can see it clearly cause mine is black anyone can help me getting rid of that paint problem other than respray the car?
And also R34 owner I wanna ask if ur driving ur car in gear 1 and 2, the response seems weaker than gear 3 and 4 also I can really drive the car smoothly in gear 2 is it clutch problem or what?
Should I check it? I just got the car about 1 week.
Thanx
Erik
https://www.sau.com.au/forums/topic/12751-curiousity-of-my-skyline/
  • Replies 70
manual is faster, and will pull hard in 1st and 2nd. make sure your pressing down on the pedal on the right, thats the accelerator :D
as for the paintwork if youve tried the cheap option with no success then all youve got left is to pay real money and get it fixed. if you dont want to then just get used to it
cut and polish is a bit harsher than normal wax and will take off all the crud in the top layer of the paintwork. it is used to bring old paintwork back to life
id suggest buying a bottle of meguliars quick wax. give her a wash and polish it really well and it should come up a treat
how do u judge hard? mines really hard cos its a daiken 5puck, the standard ones normally aint too bad
again youve got to imagine, questions like these are a little hard to answer over the internet. we cant feel what your car is like through the computer so you wont get an accurate answer on things like that.
huuehheuhu , I'm not sure cause it's like the owner or seller just paint with something to cover up the scratch, I think i won't try cut and polish if i do wrong , I'm dead. If I cut the pain and it goes white then what should i do? i got black paint hehehe
I think i'm buying maguliar, which should i do first polished or wax?
well your clutch shouldnt be too bad, and it should go hard in 1st and 2nd gear
nah youve got me all wrong, these car cleaning products arent like chemicals, they wont eat away at your paint. cut and polish just takes a small layer off the top. you wont notice it and you cant stuff it up
wax is the stuff you put on the car from a bottle. polish is the physical action of poloishing the wax into the car and leaving a shine
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
