hey all
im after one join of piping from an 89 32 GTR that comes off the "twinturbo" alloy pipe.........the one that runs under the air box
pic below
if any one has one call me on 0401 974 224
ask for Romeo
thanks
https://www.sau.com.au/forums/topic/127550-wtb-rubber-intercooler-join-32-gtr/
has any one else had this problem......of trying to find this part? if so did you have any luck with any other silicone 45degree bends? are there any out there "new" that would fit?
thanks
thanks
I THINK I GOT ONE OF THESE I HAVE MMS YOU THE PIC OF THE 2 I HAVE
