Very construstive advice there Greg, just like the one I just saw in the spotted skyline thread...
Put a resistor in line with the bulb...
Run it in series... About 1 ohm should knock a bit of brightness out of it. Otherwise get a variable pot of lets say 1-5 ohms and then it will be adjustable...
Once again run it in series...
Cost you less than 20 cents for an inline resistor and about $2 for a variable pot...
Cheap as chips...
that's like a beacon out in the middle of the sea.
i dont think u needed to point an arrow to it, i reckon we would have found it anyways.
go the resistor. if it's still too bright, add another resistor, or one of higher value.
Here you go Sean...
Simple wiring diagram for ya... Just need to wiring it in series and your sorted...
Thanks col, only problem is I've mis-placed my manual for it and all the wires are in those wierd american colours, don't know which wire is the one that connected to the head lights. :(
1.) Check the power to the White (illumination) wire. This is your power input to the light and the amount of power will vary depending on how and where you have it hooked up. The lower the power, the dimmer the light and the higher the power, the brighter the light. A common range is from 6 to 14 volts.
2.) If your tach features LED lighting such as Cobalt, C2, or NV models, and you have confirmed power to the White (illumination) wire, please visit the Ask A Question or Contact Us pages to communicate with our Tech Department.
3.) If your tach uses a replaceable incandescent bulb (check your instructions), inspect the filament of the bulb and replace as necessary. Very few of our tachometers use an incandescent bulb that is not consumer replaceable. If you believe you have one of these units, please visit the Ask A Question or Contact Us pages to inquire about having the bulb replaced.
That Might help...
www.autometer.com
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
