Someone mentioned to me the other day that Trust have a Spec M intercooler kit available (I was only aware of SPL and Spec V...)
Anyway, did some lookig and they are a dual layer 600x260x76 core with aluminium piping, delivered by Nengun for about $750.
Anyway, my question is this...
Do these kits have the same piping as the others, ie cut a hole???
Has anyone got one of these installed and has pictures/thoughts/feedback on its quality and performance, given that this is almost a slightly better alternative price wise to Hybrid kits...
Your thoughts please people!!! :sorcerer:
Edited by Bobjones
https://www.sau.com.au/forums/topic/127916-trustgreddy-spec-m-intercooler-kits/
Do these kits have the same piping as the others, I cut a hole in the subframe???
I have never ever seen a kit that requires that a hole be cut in the subframe. Some require a hole be cut in the thin, vertical, trim piece that hangs down under the box section, same as a GTR of the same model. Others (infrequently) go though the thin panel next to the battery, washer bottle or radiator overflow tank.
:teehee: cheers :P
:teehee: cheers :P
Sorry Gary I meant these still have to have a whole cut...its been a long week....
Ok back to the drawing board as I would prefer the Blitz with no cutting required...a whole saw is for a commodore not a skyline...
GTR's have holes, doesn't make them Commondoors.
:teehee: cheers :P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
