Hiya :teehee:
Just got my car (S13 Silvia) back from a wheel alignment, however it was only a month or 2 ago since my last one but during that time, I've managed to gain almost +2 to 3 mm toe on the rears? Most of my other alignment settings remain fairly close to what they last left it with which is why I'm a bit curious as to why this might happen... bushes going perhaps?
And to note, I haven't changed anything in the rear besides change rims once. Or is this change just normal?
Old alignment for rears
- Left = +1mm
- Right = + 1,4mm
Today for rears before adjustment
- Left = +3,8mm
- Right = +4,4mm
They've since adjusted it back to about +1mm.
Also while I'm at it, I was hoping on slightly less rear camber but the max they could get it to was -1.25~
I WAS planning to lower the rear by about 5mm but that would just make my situation worse, so... would aftermarket offset bushes be sufficient or should I start looking at arms? I'm guessing Toe arms may also be needed?
Thanks in advance for any advice/suggestions/answers...! :P
https://www.sau.com.au/forums/topic/127928-alignment-queries/
Funny things cars, and when you read wheel alignment specs they never seem to make sence how one day they are one reading and another day they can be another reading.
Every machine will be out slightly to other machines, unless they are calabrated exactly the same way by the same person every time, so from place to place the Alignment machine might be calabrated every week and the next place it might be every 6 months, No real way of saying what one will be more acurate though.
But basically if you went to a different place for each alignment this may be one reason why it is different in readings. from the last alignment to the first reading on your second alignment. also if you drive the car hard or even hit pot holes in the road and stuff like that, that most of us cannot avoid, or even live in a suburb that thought it was a good idea to make there driveway entrances at a horrid 45% angle, then every time you hit a pot hole, or go up your driveway it could be altering your toe slightly.
Or the first place that aligned it didnt do it right and botched up a read out.
Also your bushes could be on the way out.
You can choose.
But yes alignment specs will change from place to place, from 1 month to the next depends on where and how you drive.
Edited by DaFuca
Thanks for the reply...
I only get them aligned at the one place. But when I compared my other values like camber for the front change .2 degrees which didn't surprise me as much as the rear toe change? I'm gonna point the finger at bushes I think <_<
Hiya :)
- Left = +1mm
- Right = + 1,4mm
- Left = +3,8mm
- Right = +4,4mm
Thanks in advance for any advice/suggestions/answers...! :D
No HICAS
Adjustable bushes will correct the camber.
Toe change is usually caused by;
1. Accident damage, hit anything lately?
2. Worm ball joints/bushes on the steering arms, I assume the aligner checked for that?
3. Loose adjuster, any sign of the lock nuts not being tightened when the last alignment was done?
:D cheers :D
Edited by Sydneykid
Sk, does toe change affect the car veering to the left??
I forgot to ask ECS what my front toe is at..
(just got adjustable castor rods put in) Car is much more firm and stiffer, but at times it still veers to the left. A lot less now, but i have a feelin it could be my old tyres also..
Or do i need my radius bushes replaced??
Cheers SK.. :)
Edited by siddr20
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
